arty66 »
https://forums.nicoclub.com/arty66-u215793.html
Sun Feb 10, 2013 10:15 pm
Hi,
I'm new here. Hope you can help me out with my Altima. I recently got a 2006 and the ride height is messed up on it. It's got 100k miles on it, and in the front of the car it has new quick struts, but in the back of the car in has the original factory suspension. I've measured the ride height and in the front is almost half an inch higher than factory spec, and the back has sagged and is a whole inch below factory spec. The front has a ridiculous fender gap and the back has none. If I push down on the car in the front the springs are really stiff, and in the back they are really loose.
I have an Eibach Pro Kit that I want to put on it and new struts to get rid of the fender gap and to even out the suspension. I want to replace front and back springs and struts. The problem is the car has quick-struts in the front so a lot of parts are missing. What will I need to go back to the regular springs and struts setup?
Springs
Struts
Mounts with Bearing
Rubber Insulators for Springs (I'm guessing I will need to get new ones for the rear as well?)
Strut Bellows
Am I missing anything? I think there is a metal plate that the strut mounts and bearing mount into? Is it included with a mount or will I have to buy one as well?
