messed up idle
jtolton
Car: 1992 Nissan 240sx
i drive a 92 ka24de hatchback..just got an oil change yesterday, fuel filter got changed also. started car this morning and my car is idling at like 3 k and its loud. If i let it sit, it wont go down and when i rev it, it will go up and come down very slow. when i turn the car off, right when it is about to shut off its like it stalls. any suggestions would be very appreciated. also the notorious chain rattle..with the top guide removed ..
Denko44
use ur tps to adjust ur idle.. then let us know whats up
jtolton
ok i will try, ive heard adjusting it doesnt usually do anything, i havent checked but with my luck its probably already adjusted to the max.
jtolton
lol cant find adjustment screw...a little help?
94_240sx
Car: 94_240SX
It's under intake manifold. Unplug TPS sensor, set idle and plug back in. Idle should go up slightly once plugged.
jtolton
thanks im a visual learner so that helps a lot! haha now i just gotta find the TPS to unplug haha man am i ever a noob.
jtolton
NVM zerothread/254123
thanks everybody for the help..i guess i shoulda just searched a bit more before i gave up the first time.
jtolton
fixed her! yay. turned out to be my throttle cable being as about as loose as a chinese hooker in bangcock. tightened it up at both ends and car is now idling at 750. thanks everyone!
