messed up engine cover
ja105ny
Car: 2008 Altima Coupe 2.5S
i was painting my engine cover. had it almost done then i messed it up completely. whats the easiest way to remove all the paint (about 2-3 layers)
SniperJoe
Car: 2008 Nissan Altima Coupe 3.5 SE CVT, Premium, Tech, VDC.
What kind of paint ... most labels will have info on how to clean up / remove dried paint.
ja105ny
duplicolor engine enamel paint
nogears909
Car: 2008 Niagra Grey Coupe 2.5S CVT
sand blast it
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
acetone....
SniperJoe
Acetone may work as stated above ... you might try something like this as well:
http://www.caswellplating.com/....html
Not sure if either will damage the engine cover in the process ...
Scott21384
Car: 2008 Altima Coupe 2.5S - Super Black
Sand paper and some elbow grease, i would not want to be in your shoes!!!
GryStrm
Car: 2008 Altima Coupe 3.5
gosh i dont envy you...feather down the edgeds of the messed up area using 1000 grit wet...get it smooth...and feather coat..sand again...ur trying to build up the boo boo...and hit it with a final coat over the peice....i alway end up doin a wet rub down with some stuff called rotten stone...its basically a finishing powder to get your surface super smooth...then my final final coat...itll be like glass
gucio69
Car: 2008 Nissan Altima Coupe 2.5S 6MT
brake fluid will get the paint off but it might damage the plastic too.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Ok,..no one asked this but how did you mess up?
ja105ny
first of all...new to the painting. had it perfect though until the clear coat. then wen it messed up and i tried to sand it smooth it just got worse. then i kept trying to remove layers and redo but it just got worse. lol. how much is a cover anyway?
SniperJoe
Looks like around $72.00 for a 2.5 & $46.00 for a 3.5 .... Check the link.
http://tinyurl.com/6xf3fl
Pics/diagram of the parts here: http://tinyurl.com/5als7l
tuffmag
Car: 2008 Winter Frost, Altima coupe 3.5SE CVT, Premium, Technology Package
SniperJoe wrote:Looks like around $72.00 for a 2.5 & $46.00 for a 3.5 .... Check the link.
nice link bro...thanks,
adidas2go
$40 here
racingtiger03
Car: 2008 Altima Coupe Code Red 2.5S
how does it make sense that the engine cover for the 3.5 is less lolgood luck with the paint job next round!
adidas2go
Because the 2.5 cover is more intricate. It covers the intake plenum and outlines the runners individually. The 3.5 Engine cover only covers above the spark plugs and heads. It doesn't cover the intake plenum.
mpbclutch33
Car: 2008 Altima Coupe 3.5L, 6-speed, Radiant Silver.
Is there any updated Pics? I have been thinking about doing mine. Post um up if you got um.
ja105ny
just got back from vacation so i havent worked on it for a while
jaxCoupe08
Sand it completely off. Go to your local automotive paint supplier store and buy some SEM black trim paint. Use that and it will look as if its brand new.
