lilaznballer05 »
https://forums.nicoclub.com/lilaznballer05-u62220.html
Thu Nov 08, 2007 7:22 pm
Hi, Ive got an 07 Versa, with 8000 miles on it. I changed the oil to 5w 30 Mobil 1 Synthetic at around 6000 miles. I hear a few noises from the clutch when I shift, as well as the engine. When im shifting from 1st to 2nd, alot of times I hear this scrambled metal friction noise, like gears are breaking. Its the same sound you hear when you shift HALFWAY between gears 1 and 2, but let go of the clutch too early. However, this happens when i push the clutch ALL they way down and mainly when I drive the car in the morning. It is like the clutch disengages too early? Yes, I do let the car heat up. If I let Nissan take a look at it, will they charge me for inspection or is it all covered (including replacement of clutch).
Also, I dont know if all versas make this noise, but my engine makes a loud clicking noise that almost all cars make. I believe it comes from the alternator but the noise on my car is REALLY loud, I can hear it from the passenger seat.
Thanks alot!Matt
