Well I'm on my third exhaust cam on my DOHC KA in my s13. The first one broke while the car was running right in the middle of the first cam journal.The second one I bought from a guy with a '93 and I couldn't get the thing in. It would not slide into the first journal. Thinking I was doing something wrong, I made a mistake that costed me $76 and tried to pull the cam into the first journal using the other bearing caps.Well that cam busted in half and now I finally have another one and still can't get it to fit. Upon further inspection, I found several burrs on the corner of the journal that seem to be stopping the cam from sliding in. So, can I simply grind these burrs off? I think the first cam probably damaged the corner of the journal when it broke. If I grind these burrs off, will I mess with the clearance of the journal too much? Please don't tell me I need a new head.
Also, any tips on grinding/filing the burrs off and collecting the metal shavings so they are not running through my head?
