Memory Seats
Darlene
Car: 2013 Infiniti G37X
Hi, I am a new 2013 G37X owner - love it! I had my seat programmed and upon exiting, the seat moved back pretty far, steering wheel moved up, all as it is supposed to. However, I decided the seat wasn't quite programmed right (I am very short!), so I redid the memory, raised the seat a little, maybe move it forward a tad. Now it seems when I get out, although the seat does move back, it doesn't seem to move back quite as far as it did previously and even my short legs are still hitting the steering wheel! I have read and re-read the manual, googled it.....is it my imagination that the exit position is different or does it have something to do with me reprogramming the seat? There doesn't seem to be any way to actually adjust the exit position.
Thanks!
13_SkylineSedan
Car: 2x 2013 G37 sedan 2WD-7AT (his and hers)
If you have an AT it turns out you have 3 setting choices for "exit assist". Here's the service manual you want to study:
http://www.nicoclub.com/FSM/G37/Sedan/2013/ADP.pdf
It describes the preset like this:
When exiting, the condition is satisfied, the seat is moved backward 40 mm (1.57 in) from normal sitting position and the steering is moved to the most upper position and front position.
The seat slide amount and the steering operation at entry/exit operation can be changed.
Furthermore:
The amount of seat sliding for entry/exit assist can be selected from 3 items.
[40mm/80mm/150mm]
I didn't know that until I looked...
