Ok here is what happened after doing this. I switched the button back from cancel to auto. When I turned the ignition back off and opened the door the seat moved back and the steering wheel moved up. I turned the ignition switch back on and the steering wheel moved down to set position but seat didn't. But when I hold the 2 button the back of the seat moves forward to the position set for 2 but not the bottom it's still all the way back. Now if I hold the 1 the back of the seat goes to mysetc position but the bottom doesn't move forward. All the controls work when I try to reposition. The seat. I'm getting frustrated with this thing already! I'm sure somebody somewhere has had this same stupid issue and knows what's up with it... idk what else to do!kmckis1029 wrote:this might be a dumb question but have you actually programmed your seat position to the FOB you have?
while in park and car running, adjust you seat, side mirrors, sterring wheel. Then press "set" then "1". that will save your setting. (let "1" light go off) Then press "1" and immediatly press the unlock button on your FOB, light on "1" should start blinking to confirm pairing with the FOB. Of course repeat these steps for the second FOB but use the "2" button.
If you have already done this, then idk what your seat problem is...
No issues with my '08 nor '07.....They do what they are programmed to do.joemiranda wrote:I have had multiple vehicles with memory seats and never have I experienced issues like this. The seat works fine. It's almost like the seat forgets what to do...
