Memory Seat & Mirror Adjustment
jagplates
Car: 2007 M35 Sport
How the heck is the memory feature supposed to work? I have programmed the fobs for the 1 & 2 buttons on the driver's door. But the car does not distinguish between the two. It will position the mirrors and seats to whichever fob was the second one programmed, regardless of whether the fob is programmed into button # 1 or button #2.
What am I doing wrong?zeropost?cmd=newtopic&id=176#http://for ... er...d=176#
antzrus
Car: '06 M35x Premium/Obsidian/Bourbon/
Rosewood/XM/Tint/
ClearBra/SteelSkidPlate/Genuine CoCo Mats/Michelin CrossClimate2/Nav Hack/M-1
Linking Intelligent Key to a storedmemory position
The Intelligent Key can be linked to astored memory position with the followingprocedure.
1. Follow the steps for storing a memoryposition.
2. While the indicator light for thememory switch being set is illuminatedfor 5 seconds, push thebutton on the Intelligent Key.The indicator light will blink. After theindicator light goes off, the IntelligentKey is linked to that memory setting.
Push the ignition switch to the LOCK positionand press the button on the IntelligentKey. The driver's seat, steeringwheel and outside mirrors will move tothe memorized position.
Confirming memory storage
O Push the ignition switch to the ON positionand push the SET switch. If themain memory has not been stored, theindicator light will come on for approximately0.5 seconds. When thememory has stored in position, the indicatorlight will stay on for approximately5 seconds.
O If the battery cable is disconnected, orif the fuse opens, the memory will becanceled. In this case, reset the desiredposition using the previous procedure.
O If optional Intelligent Keys are addedto your vehicle, the memory storageprocedure to switch 1 or 2 and linkingIntelligent Key procedure to a storedmemory position should be performedagain for each Intelligent Key. For additionalIntelligent Key information,see ªKey (Intelligent Key)º earlier inthis section.
Selecting the memorized position
1. Set the selector lever to the P (Park)position.
2. Push the ignition switch to the ON position.
3. Push the memory switch (1 or 2) fullyfor at least 1 second.
The driver's seat, steering column andoutside mirrors will move to thememorized position with the indicatorlight flashing, and then the light willstay on for approximately 5 seconds.
SYSTEM OPERATION
The automatic drive positioner system willnot work or will stop operating under thefollowing conditions:
O When the vehicle speed is above 4MPH (7 km/h).
O When the adjusting switch for the driver'sseat and steering column isturned on while the automatic drivepositioner is operating.
O When the memory switch 1 or 2 is notpushed for at least 1 second.
O When the seat has already beenmoved to the memorized position.
O When no seat position is stored in thememory switch.
O When the engine is started while moving
