robertwb70 wrote:Finally found one after going to 6 different salvage yards (I found 1 nissan 240SX out of all of them). Put it on but the car still has the same problem it did before so I'm thinking the root cause may be the real problem and this part melting was just a symptom of that same problem.
Original problem-
zerothread?id=380029
you better post this in the technical forum and the general forum and also at zilvia.com.
try disconnecting negative of battery for 30 seconds to reset computer.i dont know much about this. i dont know why a fuse did not blow. if your resistor/condensor failed somehow, you may have damaged the ecu or the control module. you may have short in wires or in one of the ignition components. hopefully, you get lucky and somebody will know about this.
