Melted Cool It Thermo Tec
DammitBobby
Car: S13 91 KA24DET
I don`t get why I melted the this product? I only drove it for 15 minutes and this is what it looks like. I plan on calling the company tomorrow or email them and try to figure this out. Does anybody else use this product?
GEO
Car: 95 240sx KA-T
how the hell did you melt it? Was it improperly installed? I will be using the same stuff.
nissanfanatic
Car: 1992 Nissan 240sx SE
O **** man. hahahahaha
It only blocks radiant heat. You can't put it directly on the turbine housing. Use it on stuff that needs shielding. I put it on my brake fluid resovior and my brake booster line.
I was about to say damn, mine is even touching the downpipe in one spot and hasn't melted. But yea, they will tell you it only blocks raidant heat too. Says on the box direct heat of like 400* IIRC. You exceeded that at idle I'm sure.
Jookmasta
lol, ya u need to use that stuff to block heat from the heat source, not try to trap the heat from the radiating heat source. i think only klattr is using the iconel stuff and i think the other option was a ss heat shield if u wanted to cover the turbine housing.
GEO
Car: 95 240sx KA-T
the kit you got came with a turb blanket?
fiznat
Car: Grown up :(
hahahahaha strong work man, strong work!
lol the lessons we learn... I love it.
sunnys14
Car: S14
geez, that looks nasty
DammitBobby
Car: S13 91 KA24DET
According to the directions I have which by the way is very poorly written. It says to lay down the turbine wrap then add on top the wrap with shiny foil on top. So far I am not real impressed with it. I will give them a call and see what they say. Even the picture that comes in the kit shows it they way I installed it.
DammitBobby
Car: S13 91 KA24DET
It has to be wrong but I will let you know when I call today.
DammitBobby
Car: S13 91 KA24DET
Dam, I sent this email late last night and he all ready responded. Now that is what I call customer service!! Here is a copy of the email.
Dear Robert,That would be great. Let me know your name & address and I will send you a replacement at no charge, which should work.Really apologize for the inconvenience.RegardsJim
I responded to his email by asking him if what he was sending me was different from what I have all ready installed.
DammitBobby
Car: S13 91 KA24DET
Here is his reply to the last email. By the way only took him 20 minutes to respond!!
Yes, one with a different foil.
Jim HendersonThermo-Tec Automotive, Inc.http://www.thermotec.comemail: [email protected]
All I can say GEO if yours ends up like mine you will need to send him a email.
DammitBobby
Car: S13 91 KA24DET
Yet another email. These guys seem to be serious in resolving this issue. Two thumbs up for them!
Dear Robert,We are getting your replacement out today. It is possible so we can throughly check out the problem for you to send me a sample of the used & un-used foil material. Regular mail would be fine either to: PO Box 96 or 488 US Hwy 250 North, both in Greenwich, Ohio 44837.
Kind RegardsJim
fiznat
Car: Grown up :(
Good to see that, rseabrooke. Not too often are companies so willing to take care of failures like this. I'll remember this about thermo-tec.
Did you ask them if you had installed it properly? It would suck to do the same thing and have the melting happen again... they might not be so willing to replace the part.
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
damn that is great customer service. all companys should be more like them. also lets hope its the same one that structure has been using on his turbo cause his lasted for a while.
DammitBobby
Car: S13 91 KA24DET
I am sending them the whole turbo shield. So they will know exactly how I installed it and what the problem is.
Ligouri Rd
Car: '96 Nissan 240SX
Ha!I'm not the only one who's had this problemSo you said you put the header wrap on the turbo first and then put the fiberglass and foil on top of that? The instructions said nothing about the use of header wrap at all. Just cut the fiberglass and foil to a trapeziod shape, weave the wire through the long sides, install on the turbo and tighten.
I thought the melting problem was due to fuel burning in my turbo due to a leaky injector.
DammitBobby
Car: S13 91 KA24DET
You should have gotten in your kit a 6 inch by 3 foot wrap that is for the turbine(Cut to fit). Then you wrap the Fiberglass foil on top of that. Guess I how now about that one!!
Craving4Boost
Car: 91 240sx fastback
same thing happen to me when i didnt put the turbine heat wrap FIRST...however after that i didnt try to put the foilover because the heatwrap worked so well by itself
DammitBobby
Car: S13 91 KA24DET
Did you wrap it once or twice? Also did you wrap the inlet housing. The directions recommend to wrap that as well.
Craving4Boost
i wrapped it once and i can touch the turbine and its only warm...of course dont leave your hand on it for too long but it the wrap wasnt there it would burn automatically....
no i didnt wrap the compressor housing because it doesnt get hot, and even if it does get hot its not close enough to anything to burn anything..
obviouslythe more layers you wrap the turbine the better it will work. i used to think that wrapping it will make it worse since its trapping the heat, but hot air moves faster and you want the turbine to spin faster
Ligouri Rd
Quote »You should have gotten in your kit a 6 inch by 3 foot wrap that is for the turbine(Cut to fit). Then you wrap the Fiberglass foil on top of that. Guess I know now about that one!![/quote]The turbine wrap was the 6" x 3' brown stuff?...nice instructions. Luckily I have more than enough foil shield to re-do it.
DammitBobby
Car: S13 91 KA24DET
Yea, Funny I had to reread the instructions the first time I installed only the foil wrap. Burned that one in only a few minutes!!
Robert - Next time you talk to them, tell them you have another customer, I'd like to order DIRECTLY from them.
I like supporting businesses that take good care of their customers!
DammitBobby
Car: S13 91 KA24DET
Will do. After the BD Disaster I have learned my lesson!!
Maybe they can get us some before you leave to head down here?
DammitBobby
Car: S13 91 KA24DET
Saturday around lunch time my box came in from Thermo Tec! Now that is service! Anyway they sent me another yard of material with foil and another 6 inch and 3ft material to wrap around the turbine housing. I will let you all know if it works.
dsylvia
Car: 93 hatch
i just bought this same exact kit from jegs.
it was pretty clear to me that you wrap the exhaust wrap first, then the foil. i hope mine doesnt melt. but if so, i'll be calling them too.
im glad the company has great service. good luck on the second try.
Ligouri Rd
Well I completely re-installed the heat shield with the brown exhaust wrap on first. The same thing happened, it just took a little longer this time. I actually had multiple layers of the header wrap on the downpipe and it still melted through the foil. I probably have the defective foil, luckily Thermotec is sending replacement material. More props to thier customer support system.
DammitBobby
Car: S13 91 KA24DET
That is cool. Got to love this forum!! I just got my stageII running last night so I will be installing the heat shield Thermo Tec sent me last week. Hoping it will not do the same thing. If it works we need to get them to sponsor NICO!!
dsylvia
Car: 93 hatch
damn, you had the exhaust wrap on first then the foil, and it still melted. that sucks.
god i hope mine doesnt melt. i'll be pissed.
where did all of you get the product from initially? hopefully jegs doenst have any of the defective stuff.
