Meguiar's PlastX Lens Cleaner
Sopdadope
Tried out some Plastx Lens Cleaner by Meguiar's today. Good stuff.
Made my taillights look brand-spanking new and the headlights on my cousin's I30T a lot cleaner.
Check out some before and after pics. Too bad my camera sucks though, otherwise you can see a big difference.
Before
After
Sopdadope
They come in small 1 ounce packets but each packet is enough to treat your headlights and taillights even if used liberally.
I use the Nexus stuff (3 stage). Also good stuff.
Did you do the center panel as well? I did - Just avoid the "INFINITI" lettering.
Makes a big difference, huh Soph?
greg_atlanta
Car: 2008 G35 Journey Sedan, silver/black (no sunroof), 1992 Q45 (in a past life)
On early Qs the Infiniti lettering is on the inside.... more aerodynamic. :D
Ah - I see. Thanks G!
msscomm
Car: 96 Q45t / 01 X5
Sopdadope wrote:Tried out some Plastx Lens Cleaner by Meguiar's today. Good stuff.
I can vouch for another Mag's product that has proven itself to me, my mechanic and my body man several times over - I even know of one enterprising soul who goes around picking up xtra $$ "clearing" clouded plastic headlights
I use a 3 step process that can give a factory “new” appearances to plastic lens covers - get a bottle each of Meguiar’s Mirror Glaze #17 Clear Plastic Cleaner and a bottle of Meguiar’s Mirror Glaze #10 Clear Plastic Polish - approx $9 to $12 per 8oz bottle
1. Wetsand (w/copious amounts of water) to a 1500 grit (The cloudiest lenses I ever refinished necessitated wetsanding down through 800, 1200, then 1500 Silicon Carbide paper)
2. Two applications and buffings to clear off with the Mag’s #17 Cleaner using a buffer (I use a buffing wheel on lo setting w/a Dremel)
3. Two applications and buffings to clear off with the Mag’s #10 Polish using a buffing wheel - Clean up and enjoy !
This project is a damn site easier if you can remove the entire lens assembly to work on it -
