megasquirters
180sx
hello boi'sSo just finished bolting up turbo kit on my buddies ka24de, getting ready to install megasquirt pcb 3 v1 tonight, runing oem fuel pressure of 43.5 psi and use 460cc inj from rx7 low imp. Just wondering if anyone has any files worked out for it already , like some basemaps and idle etc. i think there is at least 3-4 people here with megajizzer.please e-mail me the filedenu canada.com put caps2 where it belongs.or post a link.
thanks alot.
480sx
Car: 1996 Pearl White 240sx
Im running 550's so my maps wouldnt be much use for you. While there are atleast 3-4 ppl with MS here im not sure anyone has it running well yet hehe.
Theres one guy, Chosenone who has MS running on a CA engine, but not for a KA.
The map generator for MS does a fine job, you just need to lean out the idle areas. Make sure you set your MSQ up for low impediance injectors or you will fry them.
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
theirs actually quite a bit of people on Nico who use Megasquirt I would say around 30 or more, most of them are in CA's and the 80's rides like 300zx Z31, 280z with the 6 cyl. 2.8L L28ET etc etc. You dont hear much of them because they dont visit Nico much they normally chill in Hybridz.com. The ones with the CA's are my clients.
I have several files but nothing special at the moment nor any help to you. I use FORD EDIS so my ignition wouldnt work with your setup and I have 600cc less.
However if someone with a KA MS you can use their file doesnt matter how big the injectors are, because in the injector characteristic menu you just input the size injectors, and engine info and it'll edit the map to accomadate it. It wont anything special but should get it running.
Oh yea I forgot to add if someone does post a file make sure it states what Megasquirt such as I or II, what firmware code their running for example I'm using code 2.36 etc etc because some msq files wont work with other firmwares.
