480sx »
https://forums.nicoclub.com/480sx-u50548.html
Wed Apr 18, 2007 2:44 pm
Chosen one have you ever tried to wire MS WITH the relay board? Dude, it simplifies things so much. Taping your fuse box is kind of a PITA, plus all your relays are 100K miles+ generally. I started to wire up MS without it, then did research on the relay board and switched to it.
First of all, instead of dealing with 6-8 ground wires for each sensor, you deal with one. From that one ground wire you can run wires to the 2 major ground points on the KA, and your set.
You also eliminate relay setup for the FP, which is a pain to even get at. The wires criss cross in the cab from the FP, go to the relay, and from the relay they go up underneath the dash to the ECU.
To top it all off, the relay board makes things so easy to install, and then later, to diagnose if any problems arise. Its got 20 different connectors, each one having a place where the wire or wires go into, then you tighten down the screw and your connection is made. Like the connections on an amp for car audio, except smaller.
There are other reasons to switch to the relay board im sure, but i cant think of anything else right now.
As a side-note, i just finished installing my MS unit, and tomorrow i go to test all the sensors and that good stuff. I would HIGHLY RECOMMEND the relay board.
The IAC-FCID unit is a PWM/Stepper type motor, and MS can control those types of circuts. However no one knows how to do it yet. I just left all those idle control systems connected to the ECU, so i dont have to worry about losing any drivability.
Modified by 480sx at 9:46 AM 4/20/2007
