A friend of mine sent me to this board....so this is my first post (hello!).
I have been dealing with MS (MSnSExtra) for over a year now and it is by far one of the greatest bang/buck things out there. In terms of controling injectors, it is very simple to install (if you don't mind some soldering or wiring) and very flexible. Does it do more than your stock ECUs? Not in its orginal form, but being that it is an open source project, a lot of development has taken place. I highly suggest you check out:
Http://megasquirt.sf.net/extra
I have a 94 MX6 v6 Turbo (running bluebird injectors ) fully controlled by MS. My stock ECU isn't even currently plugged in at the moment.
If you wish to remove your MAF, you need spark control as well as fuel. In order to get spark control with MS or many other stand alone EMSs that are not plug/play you need to setup a proper trigger system...like the flying magnets that SDS uses. The standard 12v pulse from a coil will not suffice for controling timing. In both the KA motors and the SR motors, I have seen the same optical Cam angle sensor....it looks just like the ones in the turbo 280Zs except it has 4 slots instead of 6. That signal along with a pullup resistor is enough to get a solid tach input. I didn't get much time to experiment with his ride as far as timing, but it appeared the stock ignitor in your disties runs on a 5v pulse....if that is the case, you can probably mod yoru MS to run timing as well without having to buy other parts (HEI, MSD, etc).
I am currently looking for an SR powered car to sponsor in the south florida area. I want to figure out the timing part 100%. If somebody comes through, I'll post the info allowing you guys a super cheap alt to rom tuning.
