So after doing a successful install of megasquirt to a CA powered 240sx I was thinking of offering my services and knowledge to our fellow CA owners.
I could build the kit, include all the FORD EDIS parts, build the harness. Program the ecu and even load it with a base map or a possible conservative tune. I would do all testing making sure it worked, even send screen shots, video of ecu running on car etc etc.
Probably the only thing you'd have to do on your part is get the trigger wheel machined or mounted on crank pulley, and the VR bracket for crank sensor, and a good tuning to correlate with your actual motor since no 2 motors are alike.
I'm thinking about like $800 for the works which would include:
Assembled and tested Megasquirt II V3.0 Built Harness.Programmed ECU All FORD EDIS parts such as coil pack, module, VR sensor, Coil Pack bracket, trigger wheel, spark plug wires.Fuses and Fuse blockand extra supplies such as heatshrinkable crimps, zip ties, etc etc.Even some GM sensors if you choose to go GM sensors.
I'm going to be creating a FULL WRITE UP in a few days so that you DIY can take a crack at it.
