MEGASQUIRT RB25 Q
Sturge
Car: s13 sil80 with rb25
Hi there, I have built my MS2 V3PCB to take EDIS-6 But having trouble trying to find an EDIS unit to go with the coil I already have. I will be using the megasquirt ecu on a skyline RB25det. From factory they use an ignition amplifier, Does anyone know if i can use this rather than an EDIS unit? if i do would i need to mod the ecu or can i leave the edis setup on the board? also any wiring info would be greatly appreciated to use the stock IGN amp.
