megasquirt map.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
did anyone happen to save the base map that megasquirtCA had linked ? im about to start up my car and i have a map from dodge neon since thats what we have been installing them on, but i want the ca map to use just to be safe.
i will also probably be asking questions im making this thread so i can bring it to the top of the pile and be noticed as i add to it so ryan, dee, all others please dont move or merge this
thanks jon
email me at [email protected] if anyone has it.
also i have my 9th toot at my sensor and im reading 10btdc is this off?? ill check and make sure its lined up properly since i have cranked it over to check oil pressure.
tyrannix
Car: go big or go home
if youre using the ford EDIS, then its correct, that is teh EDIS limp home mode, MS needs to tell it where it should be advancing to on start (And after)
dont ask me how, i havnt done it yet. but im pretty sure its just an option in megatune, you have to set for EDIS, then you can program
and yeah, sorry. i dont have that map either
CJ
Not_a_sr
thats what i was thinking, its been so long since i have actually done the reading or have been working on my car that i have forgotten almost everything i had been doing.
i have a map from a 2.0 neon with same size injectors i will probably work off that for now. i may get a b18 or b16 map also .
