Megasquirt Base Map
Xero
I need a base map for a DOHC KA-T. Just need a starting point for fuel and ignition that I can tune from. Wanted to see if anyone had one that they could send my way. It's going to be running on a MS-II v3.0, but if it's MSnS, I could probably transpose the maps over to MS-II.
thanks!!
If you have one you can e-mail it as an attachment to [email protected]
thanks again.
Chezedik
Car: 1991 Nissan 240sx
Talk to DeviousKA on the NA forums, he has one, and I thought I read that he is working on a turbo tune. Find him, and you can at least use his map to start from.
Edub1
Car: 89 240sx KA-T
Go to hybridka.com and download one.
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
My MS fuel maps are going to be way overkill for anyone elses application, but I would be glad to help you out with a timing .vex for your MS setup.
The nissan eccs fuel maps cannot be used, the data is irrelevant.
Xero
I'm really just looking for a base to start tuning from. Just enough that I know it'll start. PandaS14 said he got his to run good on the ignition map he's posted places, so I'm gonna use that for base ignition.
deviousKA
Eh, yeah that just saves me some time, probably one of my maps .
It sounds like you havent been doing enough reading on tuning your MS though, you can have that thing started and ready to tune in 5 minutes by following the proper steps, someone elses mapping is not going to help much.
Xero
oh, okay, haha. I haven't gotten far into the tuning part, I'll look around some more.
