sr20deTsomeday118 »
https://forums.nicoclub.com/sr20detsomeday118-u82982.html
Thu Apr 10, 2008 8:12 pm
SO! today i got my megan short shifter v2 installed!! woo!!basics needs to this install was
the shifter12mm wrench and socket wrenchpair of gloves
ok the key to the v2 is taking out all 6 bolts that the shifter assembly is in
the best way to remove the ones in back is by use of a 12mm wrench,and to double team the bolts from the top and the bottom, it is best to do it with the car jacked up pretty high
after all the bolts are loose you should be able to pull it off pretty easily
the install is pretty self explanatory from here on out, just reverse the order.once installed it should look like this
cap it all back up and you should be set
I was completly amazed at the throw reduction and everything is so solid now.NO RATTLE and no popping of the gears so i was really pleased. i recommend this to the max. i bought it from eMpowermotors.com for 95$if i missed anything or if you have any Q's, plz ask
