Megan springs & camber kit
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
GRPRX1
Car: 2005 g35 sedan. all stock
2008 G37 Coupe. K&N intake and stop tech slotted rottors.
I have ordered a set of megan springs that give the car a Lower rate: 1.7" Front, 1.5" Rear, all I want to do is lower the car just a little I'm not looking to slam it since it is my daily driver for now.
When I spoke to the sale's guy I asked if I would need a rear camber kit, he said no because Infiniti rear camber cannot really be adjusted, so it would just be a waste of money to get a camber kit, does anyone know if this is true? :ohno: because as I look online I do not see this mentioned anywhere. And if this is true I will most likely not lower the car since I do not feel like buying tires every 10,000 miles. so any advice or comments would be appreciated. Thanks everyone :dblthumb:
audtatious
You will need a rear camber kit + toe kit and a front kit as well. I suggest Eibach/SPL kits.
Front Eibach kit: Allows for camber, toe and caster adjustments
Rear Eibach kit: allows for camber and toe (toe bolt holes need to be enlarged)
Without those you will be replacing tires. I've just gone down that route.
I purchased mine from tunerzstore.com and point you in that direction :cool:
GRPRX1
Thanks, Audtatious
I appreciate the advice. I might just return the springs, only because I don't feel like spending another 4-500 just to lower it.
arrow23
Car: 2008 Infiniti G37S Coupe
Stillen Gen 3 CAI, HFC's and Gnd Kit
ARK Grip CAT Back
Hotchkiss Sway Bars
Eibach Pro Kit
GT Spec FSTB
Uprev Tune
20 mm Wheel Spacers
Stillen Front Lip Spoiler
You may want to consider the Eibach Pro-Kit Springs, 6388.140.
These are 1.2" drop in front and 0.8" drop in the rear.
I put these on my car and did not have to install any aftermarket Camber or Toe Kits.
I have a 2008 G37S Coupe, RWD.
After about 4000 miles, I do not see any uneven wear.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
