smocan »
https://forums.nicoclub.com/smocan-u33734.html
Sun Apr 27, 2008 10:09 am
If I were you, I would do these steps.
1. Loosen the preload so the spring is free, then re-preload the spring. You never know if the previous owner preloaded them correctly, this can cause an uncomfortable ride, well worst than if done correctly. This can be done by loosening the preload collar, then hand tighten the collar until it firmly touches the spring, then use the wrenches to tighten about 3-6 turns. Then lock it with the locking collar just below it.
2. Eye up the heights, comparing right to left so the fronts match each other as well as the rears.
3. Slap them on, and see where the car sits.
4. Adjust the height accordingly. Just loosen the bottom collar and turn the shock body until you get your desired height. Then tighten the collar back down.
It may take some time, but thats what I would do.
