Darius wrote:
Dude! I'm in the exact same boat as you except I have coilovers and still get wheel hop. I'm thinking some of the problem is from running all-season tires on stock wheels while trying to put about 250whp to the ground. Advice will be much appreciated!
Your wheel hop is prob from your tires. If your trying to run street tires on the track it wont work. The surface is not the same as the street. Try some ET street slicks.
I dont have any problems with wheel hop. Actually I dont even spin, but that could be that im running 11.5 Mickey thompson Street ET Slicks, and a posi track rear end, I have tein lowering springs, soon to be Megan racing coilovers.
Your wheel hop with the coilover setup might be you have the rear setup to stiff, For good traction its gotta be Soft, way soft!!!
Are you guys running the LSD rear end?
