remiasz wrote:but arent the spring rates and the lowering of the car 2" a lot for stock struts? what do u guys think?, spring rates are 250front and 220rear.
I have owned cars with that much of a drop and stock shocks couldn't keep up with them for long.
You are shortening the stroke of the oem shock and expecting it to handle the upgrade in spring rate.
I would run aftermarket shocks made for drops with these springs. You can run the stockers but they will not last long or give you as good as a ride as shocks set for that throw/rate.
