I have considered and researched that option. It did not seem there were really any performance gains from just the axle-back exhaust options, however the sound increase would be acceptable.infiniti_lineup wrote:I completely understand the position your coming from! Finding a midpoint between loudness and true performance increase is an extremely hard task for any vehicle, but especially for the M35/M45 because of the limited availability of aftermarket exhausts.
With that said, I want to warn you that by replacing any portion of the exhaust system before the OEM mufflers won't bring the performance gains, or even sound, that you are hoping for. The most restrictive portion of our exhaust is the muffler and, while replacing any portion before the muffler will allow for exhaust fumes to flow thru the piping, the fumes will still need to pass thru (or rather "be restricted by") the OEM mufflers. It'll be a "one step forward, two step backwards" sort of situation if you replaced any section before the OEM mufflers.
As a side note, I believe those who have replaced their OEM mufflers with Megan Axle-Back Exhaust have been satisfied and have mentioned that it does not greatly increase the exhaust noise or drone. Have you considered that option?
Thanks for info. Do you happen to know if he proved or validated this with a dyno or his butt?EniGmA1987 wrote:I heard from someone on here that he tried just doing the mid pipes and didnt get any gains. It was for the reason stated above, the exhaust although less restricted in its path gets all held up at the mufflers smaller diameter still and wont give any performance boost.
alend619 wrote:I had the same problem...first i want for magnaflow mufflers and 2.5 piping,not the sound that i was looking for and did not feel any different in hp...waste of money if ask me!!!
Bought a megan mid pipe and put the stock mufflers back...love the way it sounds now omg...just the sound i was looking for. This is the way that the m45 sport should sound Like from the factorythe car feels quicker also and absolutely noooo drone!!!!
post up some sound clips!h22 euro r wrote:go with the greddy sp2 catback i got that on my m45 sounds really good not 2 loud and not 2 quiet just perfect .but i did a meagan y-pipe an high flow and now it sounds badass.
Above post directed mainly toward 06m4.5 but info appreciated from all06M4.5 wrote:can't find the Megan Axle-Back Exhaust.
everyone is saying 3 to 4 week back-order, looks like no one has 1 in-stock
