dustyk »
https://forums.nicoclub.com/dustyk-u13031.html
Mon Jun 05, 2006 4:11 am
It's normal for your boost to go down if you changed your manifold.
You should have less backpressure so the boost should go down slightly, I had the same issue when I swapped the manifold, I had to slightly change my boost controller settings to get the same boost.
Also with the HKS actuator, shortening the rod makes the boost go higher.
