megan header problem
chenpo
Car: 1997 nissan 240sx
after i put the megan header on i have couple of problems, my 97 240sx is making wierd noise like my cat is leaking or my exhuast gaskets are leaking,and it miss fire alot. is my engine running rich or lean..?? and i cant get the egr pipe, or air resriction pipe to connect to the headers.. its about a couple centermeters off but still worried about my engine check light on.. can i by pass the egr ??.. any tricks or tips may be helpful.
LeeROBD
Car: Nissan S14
I have the same problem with my Megan Header... I can't connect the EGR tube back on so i been running with my check light on for almost a month... no other problems though... but I heard that EGR(exhuast gas recirculation) does not do much but just reburn unburnt fuel in exhuast gas trying to make exhuast gas cleaner. and some even said it was better. but some people say that your motor will run bit hotter... But mine does not run any hotter than usual. Anyway some suggest that disconnecting the pipe from the other side and connect it to the headers first and it will give you more flexablility... (I am about to try that) And about the leaking sound did you used now gaskets? And if you go to http://www.KA-T.org you can download Factory Service Manual for free.
Modified by LeeROBD at 8:37 PM 5/2/2007
Modified by LeeROBD at 8:40 PM 5/2/2007
chenpo
[QUOTE=LeeROBD]And about the leaking sound did you used now gaskets? QUOTE]
what you mean by that. well if im correct u mean did i use used headers right..?? well , i didnt i used brand new gasket that cam with the headers and down pipe. thats for that got the tip from my other posting and i havent got the time to check it bro. hey when u do it let me know if it kills the check engine light, and if possible show me some pix how u did it. im having trouble with my vacuum hoses already, too much to f@ckin touch.
o n by the way do my car gotta be a ka-t to be in there..?? in that site..?
LeeROBD
Car: Nissan S14
I don't think your car has to be KA-T, but right now is being redone... Yep I'll let you know how mine goes...
chenpo
yea bro i might try that my self too seems easier then wat i went threw.. haha.. i kinda did it the other way around
BadMojo
Car: 2007 Mazdaspeed 3
The lack of a functioning EGR system won't cause your engine to overheat, but it can raise temperatures in the combustion chamber and not only hurt emissions but, in theory, cause detonation. Maybe it would actually cause significant detonation on a KA when using crappy gas due to the relatively high compression ratio, but if you aren't monitoring knock then you'll probably never know. Needless to say, detonation is bad.
I don't have a Megan header, but with my Hotshot header the EGR tube took some muscle to get it back in to place. It didn't just line up perfectly from the start. I suppose it's possible that Megan made a mistake designing the header.
Your exhaust leak may be the result of cheap gaskets. If the ones you got with your header look thin and crappy, I'd suggest getting some beefier ones. You can also try doubling up gaskets as a last resort and always make sure you go back and torque down the bolts again (to spec).
chenpo
thankx mojo now that u said it i think i do have an extra gasket for my down pipe
