+ one I had this same issue and resolved as mentioned above. Good luck.DrifterProdigy85 wrote:Clock the compressor housing till it clears and slot the holes for the wastegate actuator.
No, just leave it as it is.DrifterProdigy85 wrote:When clocking the only thing i see that wont fit like normal is the wastegate arm. You might have to do something with the bracket to fit right.
agile_moments wrote:reclocking adapters? Unbolt the compressor housing from the center unit and twist it...
