SanoSuKe »
https://forums.nicoclub.com/sanosuke-u193144.html
Thu Feb 13, 2014 7:56 am
It's not just the damper adjust-ability . The Street Series are true coilovers style. They don't require you to use the spring buckets (OEM-style). Some say the car handles better with OEM style.
In the geometric standpoint, true coilover style is more linear because the spring is not compressed by leverage.
With the spring bucket, where springs are often placed more towards the center of the vehicle, the rate of spring compression is affected by cornering load and transient speed, and the rate of compression occurs more progressively as a result of leverage.
It's hard to say which one performs better. It's up to you really, but if you just want to go lower and don't care about the performance aspect to it, then just go with whatever is easier on your pocket. I've personally ran both setups, and couldn't really tell the difference.
Hope that helps!
