mega squirt sr20det help
s13-t
Car: s13 pig nose w/blacktop sr20det
i own a 1990 240sx with a s13 black top. before doing any big hp mods i wanna buy a computer of some sort so i can tune. my question is has anyone used a mega squirt ecu with an sr20det? and if so then is there a write up or a helpful place that will steer me in the right direction? also if there ia an easier way to have a tunable ecu for cheap then please let me know
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
I've megasquirted my KA-t it's not that hard to do. SR coilpacks might make it a bit harder but i can't see it being too bad.
If your going to go this path i highly recommend the MS2 and the MS2 extra code.Here's that specific forum http://www.msextra.com/index.phpJust search sr20 you'll find a TON of stuff.
s13-t
thanks, yea there is alot of stuff there but i couldnt understand much of it
krazydriver
yeah.... that's how alot of megasquirt is.My suggestions study study study, read more, study more, build your unit, build a tune for it, test it on the stimulator, wire it into the car, test and repeat. Once you got the engine started, start playing with the tune.
http://www.megamanual.com/index.html - this is your new best friend.http://diyautotune.com/ these guys are awesome, it's where i got my kit from.
I spent about 3 months studying the megamanual and playing with megatune before i even got my megasquirt. Then i built it, played with it for another week doing all the testing. In ~4 hours i wired it into my car, I actually got it to start the third time cranking it. Stock KA at that point, it ran rich but i was just playing around. Over this winter i built my turbo kit, retuned for 555cc injectors and have been having fun with it ever since. This time around, car fired right up the first time, and other then being overly rich under boost (initially) everything runs awesome.
I can help with the tuning and building. I think for the coilpacks though your going to have to run 4 separate coil controls, as well as getting some type of wheel setup. Just read alot and i'm sure you'll find the answers. I know someone on the megasquirt forums has done it before.
s13-t
yea i read alot and came to the same conclusion, some wheel control thingy... loloverall i have decided to get an apex power fc. a friend that used to work in cali building vtec dragsters and sr's or his own recomended that i get the apex. just easier to use, plug and play which is what i need
