andygold »
https://forums.nicoclub.com/andygold-u240494.html
Thu Oct 23, 2014 10:46 am
2015 SL here. Same issue! I get a total of 6 AM stations, all with static (not ignition whine), and the closest FM station to where I live sounds like it keeps going from stereo to mono, along with static. When I travel a few miles further from the station, I start to lose it completely. My 3 other vehicles get that particular FM station perfectly. The XM sounds just fine, without issue, as does the rest of the system (BT, AUX, CD, etc...).
I've read that some cars have arrived with the antenna just barely plugged into the back of the radio. How does one easily access the back of the radio? Can it be done from under the dash, or must the unit be removed? Is there any sort of "gain" adjustment for the antennae? And from looking at parts diagrams, it looks like the antenna wire leading from the antenna to the radio is multi-piece. Is this correct, and if so, can the connections be easily accessed or do panels and headliners need to be removed?
I've also read that someone unscrewed the flexible antenna, cleaned the threads and then screwed it back in place and this supposedly helped...
