Mechanics opinion on freeze frame data
waynegarcia13
Car: 1997 Nissan Hardbody Pickup 2wd
2.4L: custom made cold air intake,
oil cooler, suspension lift, exhaust,
upholstery, stereo sys., paint
My 97 hardbody ka24e has a misfire issue. Long story short the wire bundle connecting to the distributor got stuck behind the water pump pulley and wore threw 4 wires insulation partially and started causing all kind of weird problems even after i re insulated and re spliced them. Here is the freeze frame data I did it at idle, 2000rpm's,3000rpm's,and 4000rpm's.
Please correct me if i am wrong but i think there is a vacuum leak and the map sensor is not good. Look at the fuel trim at idle and at all of the others, see how it drops in sensor 1, that should indicate a vacuum leak. But i don't hear anything or can't find it. I also am coming up with a cam sensor circuit code, i believe on the hb the crank angle sensor is the cam sensor which is inside of the distributor
