mechanical water temp gauge?
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
who is running this type of gauge...and where did you put your coolant cantact point...
480sx
Car: 1996 Pearl White 240sx
People have used the coolant bleeding hole on the intake manifold itself for the water temp gage. The threads need to be taped out to the right size, and then the fitting just screws in there.
gumby74
I have an Autometer Sport Comp gauge.I have it run into the upper radiator hose. You can either buy a fancy inline adaptor or go to a salvage yard and pull one out of the lower radiator hose.If you look at the lower hose you will see the adaptor. It runs a switch for the small fan behind the bumper. Grab that, remove the switch, insert gauge probe with some teflon tape. Much easier than drilling and tapping your manifold.
martins_240sx
yeah I already got one from the junkyard...my sensor was to big...autogage...so I made this
I just have to figure where to mount it
bloodsport
Car: rps13 KA-T
i put mine in the top radiator hose
