mechanical or electrical
ballsout
Car: 1990 nissan 240sx
i have a 90 240sx, i want to start buying my gauges but im not sure weather to go mech or elec. whats the diff?
Chris28
Car: 92 s13 KA-T
Boost can be mechanical, everything else electric.
Electrical means there is a sensor somewhere on the engine/in the engine bay that sends data via electricity to the gauge that is inside the car. Mechanical means there is actually resistance against the needle to make the gauge move. This means with an oil pressure gauge, you are bringing oil into the passenger compartment. Fuel pressure, same deal.
Edit: why do you need aftermarket gauges? Are you turbo?
ballsout
reason being is that im going sr20 soon so just want to have gauges and stuff ready to go
jessetang
Car: 1995 240sx
One cost more, one cost less. The one cost more is easier to work with.
Now it is your call.
ballsout
so its all about cost and labor. even if i go sr20 would that make a difference
Chris28
Car: 92 s13 KA-T
Makes sense. Good preparations.
Get a mechanical boost gauge. If your tubing breaks then you have a boost leak, but it's only air. If an oil line breaks in your car, then all your oil is leaving your engine and spilling all inside your car. Same with fuel. Leave those electrical.
Good luck, we're all counting on you.
ballsout
ok so mech boost and everything electrical. thanks for your help just trying to get this done right
