Raxephon »
https://forums.nicoclub.com/raxephon-u18453.html
Sun Nov 30, 2008 4:04 pm
I replaced my clutch fan with dual electrics, but not for any BS horsepower gains.
I run dual electric fans , but I usually only need 1 running. This in turn gives me a fan to use if the 1st one decides to crap out.
I also like having the room to get down in there to change/check belts without scraping up my hands/wrist.
I don't have to worry about the fan blade cracking or splitting anymore, like is so common with most Q45 clutch fans.
I don't have to worry about the clutch seizing anymore and shaving itself off at the water pump, leaving me stranded without a fan or a water pump.
I am also planning to upgrade my alternator to a higher amperage unit soon so alternator life should no longer be an issue.
The noise level is almost equal between the 2 options, but only when I am running both electrics is it comparable to the clutch fan.
And for you horsepower junkies, my M90 puts out way more power than any clutch/electric fan mod out there.
