Alright, if I wasn't so inept at Google search and had a little more vehicle knowledge, I could probably figure this one out, but would like some expert (or at least well educated) information on a towing setup I'm looking to acheive.
1. I'll be towing a 13ft Sprite Trailer (Approx 1500lbs, max 2000 with water and supplies). The trailer is quite well balanced and will cause very little tongue weight, at most 100lbs which can be adjusted on where in the trailer I put things.
2. Between the trailer and the Pathfinder I'll have a Versahaul hitch hauler with a 230lbs (wet) dirtbike (
http://www.versahaul.com/vh55.php). Factor in another 100lbs for the hitch hauler.
3. I have an after market Class 3 Hitch with a max tongue weight of 600lbs.
I'm not maxing out my towing capacity or my tongue weight (though close with the tongue weight). Is there anything I'm missing or should be concerned about? My tongue weight is my biggest concern as I'll be looking at approximately 450lbs on it. Also wondering if I should look into a transmission cooler or upping the quality of my brakes.
Thanks in advance for any educated answers.
If I could afford a Nissan pickup right now I'd consider replacing the Pathfinder, but the only thing trade value with it is a Dakota Quad cab and the thought of buying and American vehicle makes me throw up in my mouth.
