measuring speed
jab11185
Car: 1992 Nissan 240sx
well since it's too much of a hassle to fix my broken speedo i was wondering if ne1 knew of something that'll show me how fast i'm going like gps....i dunno how expensive it is or what cheap alternatives there are to speedos....sorry if this thread seems kinda dumb...:D
Ender_Zero
Car: '03 Base Z, '91 S13 Coupe
why dont you try guessing by rpms? just get a buddy to go beside you at certain speeds and figure what rpms your at with different speeds.
unless you want to know exactly, then why is it too much of a hassle to fix your speedo? im sure whatever you do is cheaper than going the GPS route....
aspinballer
Car: 1995 240sx
i got a sweet GPS from walmart $80 closeouted from $200. or count the lines, something like...if you can one per second~60mph. well on the interstate its close to that.also, on the bottom of the tach under the bezel is shows 60mph=a certian RPM. on my 95.
Drill_Sergeant
3rd gear at 3K rpm is about 40mph
5th gear at 4K rpm is about 80mph
bcar240
Car: 1993 240SX HB
get one of those magnet things people but on bicycle tires to measure speed and distance! I have seen some that measure up to 60. :D
240dreams
Car: 240's
a turbo timer
silkk
Car: 94 B13
89 S13
07 S2000
get a g-techand you can measure your hp and 1/4 time while youre at it =P
240dreams
Car: 240's
gtech sucks on 240s. i had one and the rpm measurements were always off.
240SXer
Car: 1995 240sx SE (2jz powered)
The Gtech sux on all cars, it reads faster, but it's still a decent tool. Get a turbo timer, like the greddy profec B Spec2, it has Speed on it, or a Conzult thingie, those do speed too, or i'm sur eany electronic speedo which uses pulses will work.
