Meagan Downpipe
TogueDrifter
Car: 91 B13 SER
I was looking at downpipes for the Sr and all the DP are a 3" design staright all the way through except the Meagan DP. From what I understand, it has a 3" inlet and a 2.75" outlet! Anyone know why that is? and wouldn't a 3" inlet and outlet be better or does the meagan design increase flow or something?
Dori Dori
Car: Cars of course
They all taper out after the turbo since the turbo outlet is not 3"...look closely at the top of a Greddy, Blitz (which the megan is a copy of IIRC), or any DP on the market, they all do that.
codyace
Car: S14 w/redtop
Not sure where that rumor came from??
MR Downpipe:
3"
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
IIRC pretty much all dp's are 2.75 in 3" out or they say 80mm but the inlet fromt eh housing is a littel smaller
TogueDrifter
Car: 91 B13 SER
good to know. Does it replace the cat?
heavy1metal
Car: 1990 240sx
nope, doesnt replace the cat :-(
boarder55167
Car: 97 s14
im using the megan downpipe and it bolted right up to my apexi 3 inch catback exhaust
Neil
Car: shooting laser guns
my greddy O2 elbow outlet is 2.75" so it matches perfect to my megan dp.
Turbo XS "hks style" elbow is 2.5 out,
i cant believe people spend $200+ for a blitz
driftsil40
Car: 240sx
the downpipe thing kills me and yes the megan is 2.75 inlet diameter. I have a 3" outlet an dcant get a downpipe, guess ill have to make one, but im lazy and dont want to
Neil
jeff would be happy to... probly run you like $100 and include a flex joint
as a matter of fact the CIP downpipe IS a megan... badge is still tacked on and everything, its just modified with a flex joint welded in. Its only like $15 more than an unmodified megan. really worth it if it relieves any stress at all from the exhaust manifold
driftsil40
Car: 240sx
Im not that lazy, Ill make one probably this winter, I don think my precision sc5031 woll like dumping into a 2.5 flat paice of flange in the pipe. and I will probably put a peice of flex in it maybe not nesceasry though seeing i have solid motor mounts but couldent hurt. if you dont have them and you have a header you better put in a flex or that bad boy will be a breakin
