NISMO_RB25 wrote:You send the upper KA and the upper RB. You then use the lower KA harness and connect it to your RB transmission if I remember corectly.
JonPowell wrote:Its cool...no worries....
I like to get the KA upper & lower & the RB upper & lower...Just handle the whole thing.
There is a little work that needs to be done to the KA lower harness to make it completely compatable with the RB motor.
FAST-DATSUN wrote:Some of the harness are taking longer here The R34 we are working on getting the factory manuals from Japan and getting the wiring translated before to gets sent here takes time. the rest depends on how many I have to do when your harness get here and our work/ race schedule with the exception of the R34 harness usually take 2-4 weeks because I usuall have 20+ harness(RB/SR) in house to do at any time.. Sorry Mack
FAST-DATSUN wrote:our wiring we hook up the Nissan consult plug, the OBD2 plug will not work as the computer is not compatable, the wiring is done to make the gauges work, but the tack and speeedo must be modified to tread the RB 6 cyl.....and speedo recalibrated. after the manuals are transulated mailed to me.. WE "recomond" that you use aftermarket direct reading water temp and oil pressure gauges as this are important to the life of your engine!!!!!! Mack
FAST-DATSUN wrote:the wiring is suppose to be getting translated in Japan right now..Hope to get them in a couple weeks or less..
