Mckinney rb20 mounts in a s14
Flamereka
Car: 89 240sx, 96 240sx,98 subaru 2.5rs, 07 wrx
I got the mounts and the instructions are for a rb25 which I was told by them is the same install. THe install talks about denting the firewall for the starter. Do i really need to do this or is that rb25 specific. Whats the point of mounts if I have to hammer in the firewall. I don't want to get engine in then figure out I need to take it back out.
nekoabandoned
Car: s13 silvia
look at where the starter needs to be , take a really big ugly hammer and smack that area ive done 4 of these swaps and 3 out of the 4 we had to take the motors back out and smack it some more. but in all truthfulness your going to be hitting the area that's in the transmission tunnel , more of a upwards motion right at the opening. (its 5 in the morning i hope this makes sense..)
hammer as much as you want, you can always make it look pretty after you have the clearance
RustspecS13
Car: '74 260z and '88 300zx turbo
Keep in mind you need to make it wider then deeper. I went about twice as deep as I needed too and not wide enough. My starter would contact the firewall at idle. It was annoying.
~Alex
FAST-DATSUN
Starter location is the same on the RB20 and RB25 so YES...
FerrariTruck
nekoabandoned wrote:look at where the starter needs to be , take a really big ugly hammer and smack that area ive done 4 of these swaps and 3 out of the 4 we had to take the motors back out and smack it some more. but in all truthfulness your going to be hitting the area that's in the transmission tunnel , more of a upwards motion right at the opening. (its 5 in the morning i hope this makes sense..)
this man is telling the truth.. I hammered mine in about an inch deep from the front to back and starter (the trans really) is hitting.
I need to pull the motor out again and hit center out to the pass door if that makes sense.
If you dont do this esp with the mckiiney mounts which i have as well . You are gonna have a hell of a time lining up the motor and it will sit croocked and still hit the firewall
