Cesium »
https://forums.nicoclub.com/cesium-u121041.html
Wed Nov 26, 2008 7:24 pm
Hey guys I'm in the process of putting an RB20 into my S14. I put the McKinney mounts in today:
Note the passenger side (left) mount. The bracket that points down doesn't exactly match up with any flat face on the crossmember. Also, they both interfere with the power steering cooling loop.
A better view of the passenger mount. Note about 1" between the mount and the crossmember vertical wall.
The driver's side one looks ok, but still interfering with the PS cooling loop.
Did I put these in wrong? Backwards? :
Are these even meant to be used on an S14 x-member?
Keep in mind that I got these from someone who gave up on their swap (maybe this is why!) and they are about 2 years old at least. Must be an older model of the mounts.
Or are these just messed up like that? I can probably build a spacer for the passenger side one to fit, but I'd like some input from the more experienced swappers on here.
Thanks in advance for your help.
