Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Fri Dec 07, 2012 9:14 pm
Back when I was using McKinney mounts, I had a similar issue. Whenever I bolted the bottom wing down onto the sub-frame, I would get some heavy vibrations, more than normal. I bought a 12"x12" piece of solid poly-urethane, 1/4" thick. I cut two 1" squares out of it. Then I placed each of those squares in between the sub-frame and the front lower wings, solved all issues. It doesn't make sense why I was getting the vibrations as the engine was mounted to the hockey-puck mounts and not touching the sub-frame. But it worked for me.......
