once the motor and transmission are in you can put all the support brackets back on. Take the downpipe off. I left everything else on and got it in just fine.
Pull the KA and transmission through the top. that will be the way you drop the RB25 in as well.
why not leave the powersteering? the lines bolt straight on to the RB pump.
if you aren't keeping the AC, remove the compresser, belt and tensioner. it is just easier to do it when the motor is out.
you will need to have the radiator out of the car, and the belt driven fan will not fit.
don't forget to dent the fire wall as the instructions show.
disconnecting your steering shaft will also make it a little easier to put in.
good luck, and don't worry as soon as you start doing it, you will figure it all out.
replace your clutch while you have the motor out of the car
