Right now I am in the early early stages.
Alright, from the beginning:
My first swap that I had ever done was a SR into my 240, the power felt really good until I blew my turbo
So, while saving for a new turbo and BOV I ran into a 2005 Altima SE-R. (Not literally, although from the picture it's fate is still sealed)
After some research on the possibility of the Altima engine working in my car, I purchased the Altima for less than the cost of a turbo. The engine still runs, and the car actually still drives (had to drive it into the garage
In that time I also picked up another 240 hatch that is in better condition than the other one. (Will insert picture when I get home, I'm at work working hard right now.... lol )
Currently I am in the process of dismantling the Altima but once I have completed that it will be prep work for the swap and other things as well.
Here are my plans:
- VQ w/ 6 speed MT (obviously)
- Silvia front end with 180 side skirts and rear bumper undecided
- I want to paint it a 350z burnt orange with a touch of red added and a black roof (see pic below for color that I found to be close to what I am looking for)
- Altima front seats (re-upholstered to remove the SE-R logo, since the last owner cut the driver side logo out anyway....)
- Altima dash including gauges ( THIS part is going to be interesting, I have no idea how I am going to accomplish this right now, I bet the contour along the windshield will be totally different between the two cars haha, but I want to at least try)
- 05 350z ECU ( May end up using the SE-R ECU and wiring harness, as finding the 350z harness is proving very difficult )
- 300zx brakes front and rear ( I have TT ones from a donor car that my brother and I bought for his TT swap haha)
- 5 lug swap ( I hear the TT rear hubs don't work due to a larger spline, has anyone attempted to attach a TT outer axle shaft onto the 240's to make it work? I'm talking from the outer U-joint to the hub. I have the axle shafts, so if no one has tried it I will inspect the two closely and do a mock-up to see if it's successful)
- Kouki Tails (To me they look amazing, so I can't go without.)
Now, before all you guys call me retarded for doing extra work on the rear hubs please keep in mind that the wreckers up here are so sad, finding parts for Civics can be difficult. So I'm open to suggestions on alternate routes here.
I'll update as much as I can on this thread, but for now, I should get back to work.
EDIT: I have read SpecD's write-up and have also gotten information from Irax, thanks to both of you so far. I'll also put this on the vq666.com forums, since Irax is trying to gather information for VQ's there.
