turtl631 »
https://forums.nicoclub.com/turtl631-u15171.html
Wed Nov 10, 2004 9:15 pm
Wow, checked out your pics. Those sidewalls are square! A roll would be good though since all it does is give you more clearance, no downside really. Also, a 3.5" drop is quite a bit. Mind sharing your wheel size and offset? I'm guessing 17x8 +25, but not sure. I really don't know what I want to do at this point, I'm trying to avoid spacers. Probably either 17x8 +28 225/45 all around, that in front and 17x9 +27 245/40 in back, or 17x9 +17 245/40 all around (unlikely though, it would probably have clearance issues). Basically its rotation vs. bigger meats out back...and I've seen both setups done so much that its hard to pick. We shall see...
