maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Tue Feb 18, 2003 7:58 pm
Notice the all alloy MB 5L V8 as fitted to the new E500 produces 339 ft. lb. from 2700-4250 rpm, and peaks at 5600 rpm (302hp). Old VH45DE with 4 valves per cylinder instead of 3 will produce nearly as much peak torque( if not in as broad a band), and still rev another 1000 to 1700 (with JWT ECU) more rpms. In fact, the current VK45DE compares quite well also. E500 being a couple hundred poonds lighter with a 5 speed auto is quicker to 60 mph, but I am wondering if the 60-80 mph time of 4.0 seconds is that much better than Dennis's admittedly perfect 1990 Q45 with JWT ECU and TCU? The MB requires a shift and the Q does not.
I bet Dennis has some times for his car.
All this and Bi Xenons and adjustable air suspension for $61K (Autoweek 2/17/2003;pp. 68-69) Notice braking with new electronic application is no better (tire limited?) than stock Q (at least the first application).
