gianavel »
https://forums.nicoclub.com/gianavel-u49666.html
Thu Jan 31, 2008 11:02 am
The VH41 and 45 are different in a number of ways. A handful of the bolts do line up. It is where the starter motors switch sides that the pattern changes. The other bummer is the dowels are not the same.Of the ten bolts in each bell-housing seven line up. Four in the top half and three in the lower half.
If you could drop me your email I can send you some shots of two side by side and on top of each other.
For our VH41 to RB box adaptor we had to play with so many different ideas, I got sick of looking at bell-housing. The upside is I have a lot of photos. We compared 45 to 41 to AWD 41 all in relation to the RB box.It's a lot easier when you have them all sitting next to each other.
The biggest thing that got me is how serious the bolting arrangement is on the VHs compared to the RBs 25/26!The adaptor plate we make took a lot of R&D but it looks pretty good now, so it can be done! We've got a couple out there now.Ours is designed for use with the AWD 41 and mates it to the RB AWD box but the patterns on both ends are the same as the RWD variants. So if I can be of any help with your set up,(measurements photos etc) let me know!
Cheers
