Just curious, what's stopping people from switching the starter the other way and reversing the polarity of the starter wires? I thought the 300ZX starter opening was sort of hexagonal shape and you could flip it over. It's been a while since I saw mine since I mailed it out to youtmorgan4 wrote:Thanks! I figured after playing with it for a while that there is no possible way to get the "nose" on the Z32 starter to clear without cutting the block. I wish I would have just cut that whole thing off while it was out.
And for anyone curious, the Z32 starter with the stock, unmodified manifolds is a VERY tight (maybe too tight) fit. I cut all the heat shields off the manifold but left the heat shields on surrounding the cats. The starter would not fit between the transmission and passenger side cat with the heat shield on, so it had to come off. I'm still not sure it will fit, but I'm fairly confident it will.
Flipping the starter over would 1) cause the gear to be engaged with the flywheel all the time and 2) it would make it harder to fit. I'll have to get some pictures which will explain it a hell of a lot better, but it was VERY close to fitting without cutting the block, but it had to be cut none the less.SSDwellah wrote:
It's in a Pathfinder.thejapino wrote:tmorgan4, What car are you doing the swap on? G50?
