Maynards CA Rebuild Thread
Racerx2
Car: 89 nissan 240sx coupe
Hey guys... recently i popped the head after slamming on the ca18det for two years.... this little robust motor can take a beating and after im done here its really going to be putting down some power... I'll keep you guys updated with pics thru the build.. and let you know sum things i learn along the way... peace...
float_6969
Welcome to the CA forum! When does the build start?
Racerx2
Started yesterday... lol.. Engine getting loose to the strip down process..
Racerx2
Ca_Silvia
Plans for the rebuild?
Racerx2
Couple pics of how the butterfly secondaries work in the intake manifold....
float_6969
In all my years, nobody has ever actually taken a picture of them like that, thanks!
Racerx2
No prob.. I was quite intrested so i posted up some pics for the others....
Racerx2
Started the clean up on the engine bay here... going to look hot when im all done with the wire tuck as well...
Racerx2
Where the head gasket blew....
Look at all the goodies!! woohoo...
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Your motor mounts look a little tired. What are the plans for the engine?
Racerx2
Yah i know.. i plan on getting nism mounts.... my goal is to hit around 300hp... im getting forged rods and pistons... metal head gastket with some arps... and running a t28 turbo..... and if my bank account can take it i'd like to get some pon cams to drop in before i assemble the head.... hopefully that will take me there....
Racerx2
More pics tomorrow guys....
float_6969
for 300HP, the rods and pistons are overkill. Like, LOTS of overkill. As long as the cylinders don't need bored out, get new rings, bearings, and a set of ARP rod studs and don't worry about it. Really, I wouldn't even worry about it up to 500HP.
Now if the cylinder walls are done and it needs bored out, you'll at least need pistons. Get the CP's, they fit awesome and no clearance issues with the squirters.
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
seeing the car without the engine takes me back to when i first boughty my car..boy am i glad its runs finally xD
what kind of metal head gasket you planning on running? and isn't it that the RB25 head studs are the same?
Good luck annd keep us posted!
Racerx2
Here are some pics of the cylinder head tear down... surprising that everything was actually very clean.. also valves, valve springs, retainers and guides all spec out almost to all standard values...
float_6969
You have the head off, how do the cylinder walls and pistons look?
yohnp
Nice!!!
