heat adds more resistance to the electrical system. thats why when you start it when its been in the sun/ or hot. try to do a voltage drop in your cranking system and maybe your ignition system.silk240 wrote:so if its not getting enough juice then the battery might not be powerful enough. but i dont understand why it gets worse when it sits in the sun all day? unless the heat drains the battery or something.
