maybe someone here can help << 90 s13 with SR
burntricer
Car: 90 S13 SR20DET Redtop
bit of background.
Stock s13 SRStock turboRe-circ'd bovFMICBKR6ES11 plugs gapped at .28
I have had nothing but problems. i was running rich forever, i checked - fuel pressure = good, according to the FSM- MAFS = getting good voltage, and wiring is correct- TPS = set to FSM voltage - CTS = was bad, replaced- NO boost leaks- Timing is DEAD on - NO vacuum leaks- i pull 12 InHg at idle- I cant boost past 5 psi, or it sputters and breaks up
HOWEVER
- when i keep the vac/boost gauge at 0 i can redline it, i dump into the next gear, aslong as i roll into it, it still can be redlined, but the SECOND get into boost and hit 5 psi, it coughs and puffs black smoke and goes into a rich condition
- My intake system is 1000% free of leaks,
- My Vacuum system is 1000% free of leaks
- when i disconnect the wastegate (tie it open) the car runs fine, redlines fine and drives just like it should NA, no torque, but it still runs
- When there is no load on the engine, i can rev it and it will generate boost, it will boost up to 5 psi, the boost gauge will bounce back and forth to 0psi and it will shoot black smoke out the exhaust, rpms break up and bounce all over the place
im so lost
